View the thread, titled "On/off peak water tank switch help" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
PaulWooder
Hi, I have a Water tank with two immersion heaters. The off peak switch heats the bottom immersion and the on peak switch heats the top immersion.
my problem is the top immersion does not give enough water for a bath in the evening.
can I rewire the on peak wire into the bottom immersion heater too? So that when I do flick the on peak switch a whole tank is heated. I know this will cost me more but I need a tank full early evening.
I have also purchased a timer so I was going to do the rewiring as above and put a timer on the on peak switch.
any advice would be much appreciated.
Reply to the thread, titled "On/off peak water tank switch help" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
