Have a central heating dilema. Current central heating not working properly.
Old Oil boiler with flow and return 15mm and pump on return? Is this a one pipe system? Can't tell as tails go into floor from bottom rads (down stairs)
Between the pump and the boiler is tees off the flow and return to upstairs rads on new two pipe system. which currently only works on convection when boiler heating hot water.
Which is the best way to rectify this. If i put a second pump and bypass valve on flow to upstairs, will this work or will it just interfere with ground floor if single pipe system.
Attached is a diagram of c. heating. Any suggestions would help.
