View the thread, titled "Open vent "pumping" over" which is posted in UK Plumbers Forums on UK Plumbers Forums.
petethefeat
I have just replaced a Gledhill systerm mate 2000 with a Boilermate BP, the heating (and hot water) systems are open vented. I have a small amount of water discharging from the heating vent pipe when the pump stops! I believe the pipe work configuration is correct. Does anyone know if this will cause a problem?
gledhill systemmates are an ingenious bit of kit, i dont like them personally, but they are quite clever.
the boiler mate i dont know.
all i would suggest, if you are replacing the systemate. label all pipework, remove unit. treat it as a new installation with existing pipework.
shaun
Reply to the thread, titled "Open vent "pumping" over" which is posted in UK Plumbers Forums on Plumbers Forums.
