View the thread, titled "Open Vented System with Integrated Pump" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
jcoconnor
I am installing a warmflow UP120HE condensing utility boiler, but am unsure of where to place the Cold F/E and Vent pipes.
The recommended way appears to be between the Boiler and Circulation Pump. (e.g. as per Position 5 in: J.Mac's Pump Tool )
However, the integrated model has the pump connected directly to the output of the boiler which means I would have to modify the company supplied pipe work on the boiler which I am reluctant to do.
One option would be to remove the pump from the boiler casing so that I can fit the Vent and F/E pipes between the boiler and the pump, but I would assume this could invalidate warranties.
Suggestions ?
Thanks - John
Reply to the thread, titled "Open Vented System with Integrated Pump" which is posted in UK Plumbers Forums on Plumbers Forums.
