View the thread, titled "outside soil vent near flue outlet" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I
IST
I am running a 4" soil pipe up a wall with no windows to open vent. There is a flue outlet on the same wall near to where i want to run the pipe.
Is there any building regs reguarding the distance you have to keep the soil pipe and open vent away from the flue outlet?
I wouldn't have thought it would matter, as long as there was roughly 500 clearance?
could anyone help me with this?
a flue from a room sealed boiler needs to be at least 300mm in any direction from an opening in a building (which would cover the end of a soil vent) there are also requirements from a flue t an obstruction (the side of the pipe) you really need to give us more info on boiler make and model to be sure
You need to make sure your flue pipe is as far above the eaves and / or roofline as the regulations require and ditto for the soil pipe end.
i dont think there is a given hieght for a soil pipe other than 1m above any window which in most cases is above roofline on a blank wall i think it just has to be a reasonable distance above the flood level of the highest fitting
general rule was always 3ft above or 10 foot away from any opening
I think it has to be 1m above the eaves to prevent air blowing across the roof blowing down it. Will look in Building Regs later.
Reply to the thread, titled "outside soil vent near flue outlet" which is posted in Boiler Advice Forum on Plumbers Forums.
