View the thread, titled "Outside Tap" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I
iluvit
I'm fitting an outside tap, the pipe i'm cutting into is painted, would i need to replace part of the pipe put a compression fitting onto the pianted pipe so I can solder the fittings, or is there an easier way?
You need to scrape the paint off whatever technique you use, be it compression or solder. Use a green pan scrub to get the little bits off once you have had a good scrape.
BTW have you remembered to fit a double check valve between the stopcock and the outside tap (legal requirement)?
Thanks for that, and yes i've got a bib tap with double check valve already in it.
Cheers again
Dan
Most outside taps come with double check valves nowadays 😉
You shouldn't use a bibtap with integral check valve - these are for retrofits only. The water regs state there should be an independent check valve inside the property.
Taps with check valves tend to fail in frost.
Reply to the thread, titled "Outside Tap" which is posted in UK Plumbers Forums on Plumbers Forums.
