over pressured boiler help help
View the thread, titled "over pressured boiler help help" which is posted in Boiler Advice Forum on UK Plumbers Forums.
L
legzi
hi please help i over pressured my boiler and it splurted water the electrics seem to work as it turns on the flame wont light but it is clicking the pressure went to zero but when i try to turn up pressure water spurts out the top of the condensate trap how can i fix this any ideas welcome thanks
needs to be refilled to 1 bar
when i turn the taps for the pressure it starts leaking from top of condensate trap straight away do u mean keep letting pressure in and it will stop leaking thanks
help!!!!!!!! plz
Sounds like an internal leak, as theres no direct connection between heating and cold feed pipes and the condensate trap. You need a gas safe engineer to look at it, get a freind to recommend one. good luck.
Reply to the thread, titled "over pressured boiler help help" which is posted in Boiler Advice Forum on Plumbers Forums.
legzi,
Beeline,
