View the thread, titled "Overflow drip" which is posted in UK Plumbers Forums on UK Plumbers Forums.
rocketmanbkk
Friends
For years my mums has overflow has dropped.
She's due home from rehab soon & been at her place with the spark as stair lift going in.
Anyway, this drip has been investigated by BG as she has her insurance etc. Never fixed.
I got in the loft - f & e not over flowing - pic attached.
Fortic tank not over flowing although cold part at top has a lot of condensation in it.
It's a mystery.
Any thoughts please?
Thx
does it over flow at a same time in the week eg 2am in the night etc?
I'll ask my mum tomorrow if she knows what time, when hot water is turned on at controls etc.
What are you thinking?
if the heatings on expansion and maybe a blockage somewhere and the pumps forcing a wee bit of water up
BG said it was the pump, turned it down, turned it up, no change
tbh if it hasnt had a drain down for a while shove some a few bottles of cleaner in and let it work for a month or two and see if that helps
and if you see the water rising feel the temp if its warm its coming up the feed pipe
Should i put heating on & get it loft then to see if f&e tank water rises?
In that tank I can see about 3/4 inches above water line white stain on sides of tank. Pic doesn't show it well.
yea put heating on jump in loft and see if rises, if it does feel the feed hole if you can feel water coming up there your problem
Reply to the thread, titled "Overflow drip" which is posted in UK Plumbers Forums on Plumbers Forums.
