Pegler isolating valve not shutting comp,etely
View the thread, titled "Pegler isolating valve not shutting comp,etely" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Jacquie Yaxley
Hope someone can help. It appears that the cold water isolating valve to my washing machine is not shutting off the water completely. I can't get a plumber for 2 weeks, could this actually cause the valve itself to leak to the outside?
Yes it is, the hose itself is not leaking at either end but I'm paranoid about flooding as had a major flood some years ago. Could the valve itself leak?
How come you cant get somebody for two weeks? That's the sort of thing I would do on the way home for a regular customer, just to put there mind at ease.
you should be ok, valves normally leak because they're not touched. But because you've been turning it on and off you should be fine.
it's probably the handle fouling on the 3/4" nut.
or the plastic is worn and the valve just not turning far enough. Whip off the valve handle with a screwdriver and turn it with pliers or a spanner.
Thanks, you've put my mind at rest. My 'tame' plumber is on holiday at the moment. I turn it off after every wash so I presume I've worn it out. Is it better to leave these little plastic ones turned on all the time?
You've worn out one of the higher quality valves too!
ask him to replace with a pegler again or as im guessing its accessible if you turn it off every time you can ask him to fit a quarter turn garden tap in its place.
the washing machine hose will go straight on but the valve will be designed for far more use
Some say he can fix leaks just by knocking on the front door.
And that he knows the secret behind ferroli....
All we know is he's called ...............
Reply to the thread, titled "Pegler isolating valve not shutting comp,etely" which is posted in UK Plumbers Forums on Plumbers Forums.
Jacquie Yaxley,
SimonG,
