Persistent air issue in pipework through loft
View the thread, titled "Persistent air issue in pipework through loft" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Sid Viscous
Subscribed
Evening chaps, I'm having a bit of a mare with a pumped shower I fitted a few months back. The customer had an existing gravity shower fitted & wanted a pump fitting. I put an RP75PT in the loft on the original pipework, a Surry flange on the cylinder and AAVs on the positive side of the pump. However there's still air getting into the hot pipe. There is a manual vent on the hot where it comes up into the loft and this has to be released roughly weekly. Does anyone know if one can fit an AAV on the negative side of the pump or is this going to 'suck' in more air & make it worse? (The flange is deffo piped up correctly before you ask, I double checked!)
Thanks in advance,
Seasons greetings,
Stay safe!
Reply to the thread, titled "Persistent air issue in pipework through loft" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Sid Viscous,
Davey123,
