PH 8 in heating system
View the thread, titled "PH 8 in heating system" which is posted in UK Plumbers Forums on UK Plumbers Forums.
F
flyboy
I have just had a gas heating system installed. (see also thread on Power Flushing). Following the 'flush' the installer said something about chemicals in the system. I decided to get some PH paper from ebay and test the water. How accurate are these papers - its hard to tell if the water is pH 8 or 9? How do you get an accurate measurement? I think it would be much better if the pH was neutral ... how much flushing would be needed to do this?
Would this pH8 be due to neutraliser?
I remember reading once (must be 30 years ago) that if you used acid in cleaning out a system you needed to flush 5 times to remove it.
depending on flush chemical used the acidic ones require you to add neutrilsing crystals or liquid and then flush that round and then out
Reply to the thread, titled "PH 8 in heating system" which is posted in UK Plumbers Forums on Plumbers Forums.
flyboy,
newbie1,
