Guest viewing is limited
Pinhole leak in lead pipe
View the thread, titled "Pinhole leak in lead pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hey guys,
I recently had a leak dripping in my kitchen, after searching around for the source I found this.
Its under a bath upstairs and pretty inaccessible, just to make things more interesting I guess.
I think it’s an old lead pipe with one of the joints of a t piece cut short, squished a little and filled with lead to cap it. It’s this capped end that has a very small leak and causing the water to drip down into the kitchen.
What would be the best way of sealing it and stopping the leak? As it’s been squished I don’t think an end cap would fit.
[automerge]1584291890[/automerge]
[automerge]1584292278[/automerge]
Thanks for the hammer advice gmartine! Nothing I wanted to do more than smash it after it’s caused such a headache! A few little taps however and it looks much better, not a microscopic jet stream, now just a small droplet clinging on after 10 or so minutes.
I appreciate that replacing the pipe is the best solution but until then is there a better fix? Perhaps applying another layer of solder?
Thanks for the quick reply guys!
Reply to the thread, titled "Pinhole leak in lead pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
Mevdog,
king of pipes,
