View the thread, titled "Pipe configuration soil waste pipe" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi, can anybody tell me if this would be ok to use as a pipe configuration? obviously the black fitting would be replaced by underground pipework, also the 3 socket t piece wouldn't be used, and it's a bit wonky, so not sure what fitting to use on that part, any advice would be good thanks
Is that an overflow gully - the orange thing with the grate.
Are they not meant to be trapped before entering the main sewer?
Do they also not need a fixture running into them to replenish the trap?
OZ,
The trap is built in inside, usually removable for rodding /jetting through.
Guessing there was a gulley there, now removed and the junction added for a stack.
Stack would need a rodding / jetting access just above ground level.
Reply to the thread, titled "Pipe configuration soil waste pipe" which is posted in Boiler Advice Forum on Electricians Forums.
