C
cookiebun
Hi sorry if this sounds like a silly question but I will be ordering the materials online so I want to get it right. The waste from my washing machine is old and has started to crack ( it runs outside) so I want to replace it the fittings are plastic white compression 40mm inlet size 40mm, the only pipe I can find is:- white waste pipe 1.5ins inlet size 40mm width 43mm or solvent waste pipe 40mm inlet size 40mm width 43mm, help would be much appreciated.
