R
richardd
The other day I had to repair a section of 22 mm copper. The pipe was buried about 100 mm in the customers garden and the builder had hit it with his spade.
I looked in my case book for reg regarding pipes in garde areas or soil and found nothing regarding depths or sleeving . So I just repaired the pipe with two 22 mm soldered straights. I then wraped the new section of pipe I installed in denzo tape. The builer is going to cover it in
I then tight tested and purged.
Is this the correct procedure.
