Sharp Point
Hello peeps,
I have got 5 new build flats to do and the hot water is provided by a direct unvented cylinder. As the flats are located in an unsavory area, the client has requested that no copper is ran on the external walls of the dwellings. I have always installed discharges in copper to either a gully or hardstanding, but i understand it can be ran in plastic to a soil and vent pipe? this would be quite handy as the internal stacks are located about 0.5m from the current cylinder location. I know you have to use a fanny trap vertically, with the usual 300mm minimum before bend, but what type of plastic do i have to use? pushfit 32/40mm pipe and fittings or abs solvent weld?
Thanks in advance.
Thanks in advance.
