Guest viewing limit reached
plastic pipe in a central heating system
View the thread, titled "plastic pipe in a central heating system" which is posted in Central Heating Forum on UK Plumbers Forums.
padraig
Hello
I am replacing a radiator with a heated towel rail. Is it OK to connect the the towel rail using push-fit plastic pipe to the copper pipework or should I keep to copper?
Thanks.
If you want it to look good, which is usually the idea with a towel rail I always use chrome plated copper. But plastic will do the job.
wouldnt advise plastic pipe with chrome towel rail, why not use chrome pipework and use compression joints to join onto copper if your worried about soldering ?
Reply to the thread, titled "plastic pipe in a central heating system" which is posted in Central Heating Forum on Plumbers Forums.
padraig,
GQuigley67,
