View the thread, titled "plastic pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
dancinplumba
Subscribed
Not sure if this has been asked before But does anyone and I mean Anyone know when plastic pipe was first used in mini bore central heating ?
I thought I told you all about this before, BP brought out a dark blue 3/8" plastic pipe capable of water at 90 Degc I used it for mini-bore when Mini-bore first came out, about 1968 twas called Impaleyne, might not be the correct spelling, we used Thorsman round clips to clip it, yorkshire manifold were in blue all compression. I don't know why it never caught on. We used it on the double rad valve single ended with a dip pipe inside the rads. I told you it's all been done before some of you were born. There's nothing new under the sun.
http://en.wikipedia.org/wiki/Cross-linked_polyethylene
Read this 1960
http://www.youtube.com/watch?v=nv68JSydNeo
It was first used in Roman times they had underfloor heating way back then, Invented by Polycarpus Plasticus I seem to remember, then forgotten about until 1968 when it was discovered in a Roman ruin disturbed by BP drilling for oil! Strange but true, Honest.
I have come to the firm conclusion that this forum is only serious when it comes to GAS SAFE, Oh and a bit of OFTEC.
Cross-linked polyethylene - Wikipedia, the free encyclopedia
Read this 1960
Twin entry Radiator valve ABDTools - YouTube
Well, I never knew that, don't recall you having told me before, Eva 🙂
I could be spinning you lads an old yarn and you wouldn't have a clue, but I am not I have tried to see if anyone had any data on it and I can't find any, I will keep trying but from what I remember I only ran for about 2 years and it just disappeared, why i just don't know, you got to also understand then you could fit a full central heating system for peanuts copper tube was cheap.
Unifix just brought out the first hammer drills and plastic wall plugs, end-feed fitting just came out and upset Yorkshire, these were interesting times, minibore developed, cyltrol cylinder valves, vertical weighted NRV to stop gravity circulation, 3 post valves long after this .
Don Burners of somerset produce the first oil fired burners for the AGA cooker, fit loads of them
Reply to the thread, titled "plastic pipe" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
dancinplumba
Subscribed
Joined
Location
Beautiful Barlick
Heating Engineer (Has GSR)
Thread Information
Title
plastic pipe
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Thread Tags
dancinplumba,
happyflyer,
