View the thread, titled "Plastic piping for central heating" which is posted in Central Heating Forum on UK Plumbers Forums.
bassmonster
Hi all,
What are your thoughts and experience on using plastic piping for the central heating run?
Any advice will be greatly appreciated.
Would always use copper if it was down to me. If you have to use plastic though, make sure its barrier if using for Heating to prevent ingress of air and try to only use fittings in accessible places, i.e don't use them underneath tiled bathroom floors etc
Anything out of sight in plastic. Rad tails and cylinder cupboards in copper.
used it to save time in the past, wouldnt bother now though. feels better to use copper, especially as the new consumer rights laws have just changed in the buyers favour all round
I don't think many customers or building contractors would want you in the property for longer than necessary. Coppers better but cost more to install unfortunately.
Use loads of Hep2O on new builds, in the floors but never on show as that looks carp.
Ive done a few installs in Speed fit, with chrome and copper tails,
It's useful if your doing long runs with no joints but other than that I prefer copper I can sleep better at night then
Thank you you all for the replies.
the install is to go into my house as i'm going for a complete refurb...
i've never used plastic, this it's going to be my first... 🙂
I'd use copper, Makes me feel bad when I go to merchants and people buy a length of copper pipe for example and half a dozen plastic push fit elbows not that its relevant
Plastic fittings are expensive and I don't trust them, If you haven't used plastic before I guess you usually use copper ?
Our work is either new build or complete refurb, we only use plastic on heat pump installations (not allowed on biomass - see MI's) we use exclusively polyplumb pipe and polysure fittings, (more expensive I know) that gives us complete peace of mind on any fittings underfloor. Also pressure test as per MI's (usually 10 bar..) don't do it with air, (too dangerous) that will find any leaks and 'set' the connectors as well.
Think you need to check on test pressure thought Polyplumb want 18bar 15mins min / max 60 min
Sorry I wasn't paying attention to the detail, just bringing up the requirement to do it, Hence comment of MI's
Polypipe is 18bar, and I think from memory Speedfit is 10 bar..
Here's all we've got from Polypipe and JG Speedfit - anyone got anything else?
Polypipe:
1st fix installations
Pipe and fittings only should be tested. The system should be completely filled using water at not more than 20°C at a test pressure of 18 Bar which should be applied for not less than 15 minutes and no longer than 1 hour. Joint security can be checked visually and by tugging at joints.
2nd fix installations
Complete installations including appliances should be tested with water to the maximum test pressure allowed by manufacturers of the appliances and fittings.
Please note, due to health and safety reasons Polypipe products must not be air tested.
Pressure testing of the pipe system is essential, however a successful pressure test using the following steps is not a guarantee of complete and correct installation and only ensures that pipes have been inserted into fittings passed both the ‘O’ ring and the grab ring.
If pipes have been scored or scratched during the installation process a high pressure test as below may not highlight these issues.
Speedfit:
System Testing.
To ensure the pipework and fittings have been inst alled correctly, whether it be on a new or extended system, it is essential that the system is checked and hydraulically wet tested. Testing should be at 2 bar for 10 minutes while checking for leaks or pressure drops and 10 bar for 10 minutes while checking for leaks or pressure drops.
This testing, combined with other relevant checks, should reveal installation problems and is regarded as good plumbing practice. However, system testing should not be regarded as a substitute for correct installation. (JG Speedfit do not recommend air testing of pipework)
Only benefit of plastic is how incredibly faster it is to do just about any installation with it.
If I was working on my own house though where time isnt really a constraint so I would always only use copper. Its just more durable. Customer's house 10 years down the line isnt your problem, your own house will be.
It's so much quicker on installations. I hate to admit I use it all the time on heating installs. I use coils rather than lengths mainly. anything on show is of course copper. Airing cupboards/rad tails etc. I done a heating install the other week. 7 rads on. Combi. No previous heating at all. My mate fitted the boiler and I done all the rest. I had all rads hung by 12. All first fix pipe done by 5. Next day I piped up the rads with couple of drops downstairs in copper. Took me longer to do those drops than the whole first fix. Crazy
Plastic is quicker on new builds with access to underside of floor/ joists. when retro fitting its can be as time consuming as copper i think, mainly because you need to lift boards every 300-500mm or so to battern and/or clip where as copper needs less supports so can be fished further.
Find plastic sags when hot even when clipped correctly wouldn't want to use it on open vented system at risk of air locks. But have started to use hep2o more as does have benefits and these are only plastic fittings I have confidence in at the moment.
Reply to the thread, titled "Plastic piping for central heating" which is posted in Central Heating Forum on Electricians Forums.
