PLEASE HELP ! brand new concealed cistern continually fillg and running into pan
View the thread, titled "PLEASE HELP ! brand new concealed cistern continually fillg and running into pan" which is posted in UK Plumbers Forums on UK Plumbers Forums.
G
gnome
i fitted my new back to wall toilet and concealed cistern yesterday. as soon as i turned the water on the water was running into pan and the cistern continually filling .
i googled this problem and a few comments said adjust the water pressure coming into the cistern which i did via partially closing the isolating valve. this worked for three flushes and now its continually running again .
if i put my hand in the cistern and press my finger on the flush valve closer it shuts the water off and the cistern does its filling cycle fine .
so what is causing the valve to not fully close and let the water run non stop
water level is set too high so the inlet valve keeps putting water into the cistern resulting in overflow into the pan.
either adjust the inlet valve to lower water level or raise height of overflow pipe (model depending)
but even when i have flushed the toilet and the cistern has emptied the water is still flowing into the pan on the START of the next cistern refill so how can the water level be too high as there is only a couple of inches in there when its refilling
Depending on the brand of the cistern, the flush valve may be out of its guides, or something else is stopping the flush valve washer seating properly
Can you post a picture? Or a link to the manufacturer. Try removing the flush valve, they normally twist anticlockwise to take out. There nay be some dirt on the washer or the seat that the washer sits on.
If thats the case then follow oz plumbers advice. It can only be the valve isnt engaged properly with its cage or the valve seating washer is twisted [emoji837]
Flush valves are only sealed with rubber seals and the same as ballcock / inlet valves wear after time, and because everythings plastic they dont have a great shelf life, you should be able to spin the flush valve 90 degrees and pull whole top part off, you dont have to shut water off either , when you pull valve out youl find that the base has started to wrinkle preventing a seal, prob is knowing which washer to order, if stuck pull washer off and measure unless you know make of inards,,, good luck, washer is like this,
[DLMURL]http://toiletspares.co.uk/prod_desc_ts010.html?sno=298[/DLMURL]
Seeing as it was only fitted yesterday perhaps there is an assembly fault or the box has been dropped in transit.
his site wont let me add pictures for whatever reason ... keep getting message "post denied" . but the cistern in question was purchased from victoria plumb and model CNC1001.
thanks guys for your honest comments... i know it was cheap but i was on a budget and didnt expect problems with it being new . i will double check the flush pipe again too.
can you guys also recommend me a decent cistern that is good value please
whats the grohe 37762 (complete with square air button) like , cost around £65 delivered . is this a good model and can i get it cheaper somewhere else.
Grohe stuff is usually well built.
Have you checked that flush pipe as metioned? If all good then try the retailer for a new part, or replacement
the constant running has noticeably eased off today and pretty much perfect so may of needed settling in ....
i also has a complete replacement arriving tomorrow(under guarantee) so i think i may ebay it and whatever proceeds i get then buy the grohe one
Reply to the thread, titled "PLEASE HELP ! brand new concealed cistern continually fillg and running into pan" which is posted in UK Plumbers Forums on Plumbers Forums.
gnome,
gnome,
