N
It's below the boiler by the looks of it
Hold the valve with a pair of thin jawed adjustables and tighten the nut up
If this doesn't cure it, the system will need draining down and the joint re-made
Vaillant is good make and worth looking after. It could just be loose nut, but why it happened after 4 years could be a sign of increased internal pressure. It is also easy to see water on lower pipework when point of leakage is higher in system. Get your service engineer back. A leaky boiler can soon become a boiler beyond economic repair.
Time flies. Think you will find that boiler is nearly 6 years old!View attachment 28315View attachment 28316
It is coming from behind the nut on the pipe on the far right, it's only a small leak.
Any ideas what could be causing it? we've had the heating on recently and the boiler is only about 4 years old.
Appreciate any advice.
What would cause it to come loose though? that's what concerns me.
Reply to the thread, titled "Please help! leaking boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
