N
Nicola83
Hi
I'm really hoping someone here can help. I've had Scottish Gas out numerous times regarding strange behaviour with my boiler but they can never get it to recreate the fault when they're out.
Basically the boiler will switch the heating on by itself irrespective of the temperature set on the thermostat. When it does randomly switch on if I put the temp up on the thermostat then put it down again the boiler goes off as normal. The boiler has been serviced and checked etc and appears to be running ok. The thermostat was changed yesterday and has made no difference.
Another thing I've noticed is that while it does this it doesn't seem to go fully off and the light that normally flashes when it's on 'standby' if you like or that's solid while working goes off completely and the boiler is still making a faint noise as if on but not completely.
Its to been doing this since about October time ao therefore I don't think its because the water temp inside is too cold (as per the manual) and is driving me crazy. I hope this makes sense to someone here and you can help me because I'm just desperate to get this resolved.
