View the thread, titled "Plumbing advice leak" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Illuminate
illuminate
What is the best way to go about fixing this leak in 4 inch pipe which is connected to waste pipe within an industrial kitchen and so multiple work tables fixed to ground and so minimal access to pipes. It is leaking when from the bottomom of the grey 4inch where it connects to the orange 4 inch pipe but just a small amount to the side when liquid passing through wasye...
I just found the part you mentioned before this reply. Great advice and thanks for the knowledge. Shame someone has bodged it together. So that pvc pipe is not push fit but has just been solvent welded. Thanks again
correct the orange pipe is push fit only
I'm about to do this job but I just was thinking about how I will reconnect the 50mm solvent weld pipe as whoever installed it seemed to just use a lot of fittings without much straight waste pipe. What would you do?
Reply to the thread, titled "Plumbing advice leak" which is posted in UK Plumbers Forums on Plumbers Forums.
