sandi99
I am fitting in a worcester camray oil fired system utility boiler. I am doing the pipework as a DYI job EXISTING PLUMBING NEEDS ADJUSTING
I CAN'T FIGURE OUT WHERE THE CENTRAL HEATING RETURN PIPE ENTERS THE BOILER WITH THE OLD BOILER IT ENTERED AT THE BOTTOM LEFT CORNER
THERE IS AN ENTERY POINT ON THE NEW BOILER AT THE BOTTOM LEFT CORNER SAYING FEED/DRAIN DO YOU THINK THIS WHERE IT ENTERS
THE REST OF THE CONNECTIONS ARE EASY TO FOLLOW
IF YOU LOOK IN THE WORCESTER SITE IT GIVES ALL THE CONNECTION POINTS, AM I RIGHT IN THINKING THAT THE RETURN SHOULD CONNECT TO THE FEED/DRAIN POINT
HOPE SOMEONE HERE CAN HELP ME WITH THIS
MANY THANKS.
PS I WILL GET THE BOILER COMMISIONED BY A REG FITTER BUT HAVENT FOUND ONE YET.
MANY THANKS.
