Guest viewing is limited
plumbing in bradford where can i get 4 inch to 3 inch wc pan connector
View the thread, titled "plumbing in bradford where can i get 4 inch to 3 inch wc pan connector" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumbing in bradford w.yorkshire where can i get 4 inch to 3 inch wc pan connector behind the toilet pan is the lead soil pipe which i think is the 3 inch lead pipe that lead soil pipe connects in to 3 inch cast iron soil pipe out side
Might be the same answer you got a week ago from riley and whyme.
not the same last week he was asking how to go from cast stack to plastic
"I have 3 inch cast iron soil pipe out side i want to connect 4 inch pipe or 4 inch bend in to the 3 inch cast iron soil pipe elbow out side what wc connector should I use, how do i connect or what do I connect into the 3 inch cast iron soil pipe at the moment lead bend connector connects into the 3 inch cast iron soil pipe i want to make watertight connection at the 3 inch cast iron soil pipe elbow out side thanks in advance."
now its lead to plastic 😀 make you your mind ali
Most plumbers merchants will keep 3 1/2 inch to 110mm plan connectors.
Chalked and Townfanjon,
Ali is asking how to connect to a 3" soil pipe, not 3 1/2 in. There is a bit of a difference there! Read the question more carefully, please.
MM
MM,
Ali asked this question six months ago. That is quite a long time ago! Read the date more carefully, please.
Anz
Reply to the thread, titled "plumbing in bradford where can i get 4 inch to 3 inch wc pan connector" which is posted in UK Plumbers Forums on Plumbers Forums.
liaqat ali,
Dotty,
