View the thread, titled "plumbing regulations" which is posted in UK Plumbers Forums on UK Plumbers Forums.
buffy27
few questions ..
1. is there a regulation or something to state that underfloor heating pipes should be insulated ..going to and from the heated loop.
2. same with radiator pipes .is pipe in pipe sufficient for this???
3.wall mounted stat locations .. if they were placed in an incorrect location with more than one heat source supplying temp s...can they be placed over a radiator for that matter if they are to regulate a rad circuit???
4.for a sealed dhw system is 15 mm piping sufficient to supply a 300 l stainless cylinder with in turn long pipe runs for hot services/// can the cold supply be 15 mm and the hot out the top be 22mm??
i have my own answers to all the above but would really value opinions or especially if anyone could say exactly why there answer is correct as a matter of fact ??
i never really ask simle question s sorry !!!
dara.....
any idea s guys !!???
Reply to the thread, titled "plumbing regulations" which is posted in UK Plumbers Forums on Plumbers Forums.
