dleader
I've just fitted a new worcester 24i Junior in a small flat (only 5 radiators). The radiators are on 8mm microbore but don't know if they are individually connected to the flow and return or via a manifold. The boiler is apparently working fine - pressure is stable, hot water fine. In C/H mode the boiler fires but after about 1-2 mins cuts out. Seems that the water isn't circulating properly and the boiler thermostat is then cutting out. I've tried shutting the flow and return connections and using the filling loop to flush the system via various radiators (flow and return side). Don't seem to be any obvious blockages. Would very much appreciate any other ideas that people had - many thanks Dave 😀
