N
nigelP
can anyone please tell me if I can fit/extend the flue to a condensing boiler that is about 3 inches below the eaves so it terminates beyond the fascia board and gutter, thanks in advance
ahhh!, no.Some mfi allow as close as 25mm to the eaves, to answer your original Q I dont see why not, it looks a bit gash but I dont see whats wrong with it if it gets you over a tight spot? can anybody tell me otherwise?
thanks for help. as mentioned im not corgi registered but will fit the boiler on the wall ready for commissioning ...which is why it must be in the right place to start off with. the internal space makes life very awkward.the reason i need it to extend beyond the gutter line is that about 3 inches to the left of the pipe is an old external brick flue which sticks out level with the facia and I am worried about wind turbulence i realise that i could put aluminium sheeting above the flue.is it for heat or condensation.Why would any service engineer refuse to work on it just because its sticks out it cant be anything to do with the length of flue otherwise there wouldn't
be extension kits.
Vaillant and WB state 75mm from gutters, 200mm from eaves, 25 mm to soil pipes etc so I was nearly right..... ish 🙂.ahhh!, no.
really? thought it was 300mm min from lowest point of eave or vent.
Reply to the thread, titled "positioning the flue to condensing boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
