View the thread, titled "Possible air lock" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi, recently had a salamander ct85 xtra pump fitted to boost my hot water pressure, the problem i have is sometimes no hot water comes out of any tap, if i leave it several minute it will start and pump well, it as though it gets a air lock in the pump but my plumber cant fix the problem.
i have added a little sketch hopefully someone can shed some light on whats happening.
thanks in advance.
Wrong pump installed as you’ve got no head pressure also some more bad news your cylinder isn’t suitable for use with a pump as your stored water isn’t around the 50 gal mark
Reply to the thread, titled "Possible air lock" which is posted in Air Sourced Heat Pumps Advice Forum on Electricians Forums.
