View the thread, titled "potterton 24 faullt Heating staying on even when switched to just the hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
davethomas
Hi
Boiler is a potterton performa 24 combi
When the heating has been on for a while then turned off and switched to just the hot water symbol, the heating stays on,
even when the boiler thermostat is set to zero, the heating is very hot and is using a lot of gas.
The radiators are boiling hot even when the boiler thermostat is only on a bit.
I would be grateful if you could offer me any advice regarding this problem
Many thanks
Hi
Many thanks
Sounds like the Hot water microswitch is stuck on..If it is the 3 wire moulded switch flick the pin and listen for a click.
Reply to the thread, titled "potterton 24 faullt Heating staying on even when switched to just the hot water" which is posted in Bathroom Advice on Plumbers Forums.
