View the thread, titled "Potterton boiler overheat" which is posted in Boiler Advice Forum on UK Plumbers Forums.
C
CRAIG WALLING
Hi Guys.
I have a potterton statesman oil fired boiler installed in about 1997
The problem I am having is that it heats up above the thermostat on the boiler then cuts out.Then starts up again
once the stat has cooled down.It does this on heat/water demand or just water.The outlet pipe is red hot
and the inlet very touchable.I was wondering if the heat exchanger could be blocked?
airlocks, pump failing or blockage , need someone to check it out for you, must get quite noisy as well
Reply to the thread, titled "Potterton boiler overheat" which is posted in Boiler Advice Forum on Plumbers Forums.
