M
m550344
I have recently replaced my hot water cylinder tank, which came with a new cylinder stat (Danfoss Control\Limiter model). What I am having a problem with now is that I cannot get the cylinder stat to trigger the boiler when temperture of water falls below a given temperture as set by cylinder variable stat. The programmer is a Potterton EP2001.
I have live on C, and 1 and 2 wired as per orginal stat (Honeywell Cylinder Thermostat L641A1039). If I set stat to any temperture above 30c boiler will not trigger, however if I set to 30c boiler triggers and will remain on until I switch programmer off. I also found that boiler would trigger unexpectantly when programmer was set to off.
Is it likely that the Danfoss stat is not compatiable with the programmer or maybe my programmer is at fault?
