View the thread, titled "Potterton performa 24i HE" which is posted in UK Plumbers Forums on UK Plumbers Forums.
E
Eduardo
Greetings one and all.
I have a flat with a potterton performa 24i HE combi boiler.
The boiler keeps losing water pressure in the central heating system.
I have tried isolating the flow and return and the boiler still loses pressure so the leak is not in any of the radiators or pipework.
I can see no leaks from the boiler itself and am fed up and thinking of replacing the boiler like for like as it would be easier.
My question is can I still get a new potterton performa 24i, is this model still available?
Would another potterton be available that uses the same flue as the 24ihe and is an easy swap?
The existing 24 iHE has had a new expansion vessel and still not solved the problem.
I think it would be a good idea to change like for like as I could use the old boiler for spare parts should I need some.
The flat is rented so I want to get the problem sorted asap.
What are your thoughts?
Many thanks.
Why would you change a terrible boiler for another terrible boiler? Get a local gas safe engineer it to quote for a swap and see what they recommend.
Could anyone recommend a boiler here?
It's a one bedroom flat, boiler is running two radiators, a small kitchen and bathroom with shower.
Reply to the thread, titled "Potterton performa 24i HE" which is posted in UK Plumbers Forums on Plumbers Forums.
