Christopher buzzard
Hi all. Got called to the above boiler which had an intermittent hot water fault. Had it for 2 weeks and gradually getting worse. Went on Friday and couldn't get it to fault. Had it running for 5 minutes and it didn't drop out once. Kept turning tap on and off but still no fault. The customer said that the radiator icon on the front panel flashes and boiler has to be reset to get it working again. Done usual checks, burner pressure. Checked fan which seemed ok. Rang technical and without it going to fault they weren't much good. Customer has rang again today to say it's playing up again. Can anyone point me in the right direction for things to check or has any1 experienced this fault. Regards to the Heating side, I tried that and it didn't go to fault but female customer said it would go to fault on Heating also, where as the male says it's hot water only that fault occurs.
Regards
Regards
