View the thread, titled "Potterton Perrymatic Jetstreme Mk2" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Coombland
Help please.
We have the above boiler in our house supplying hot water and central heating. Has been working fine until 2 weeks ago, now it is cutting out every 48 hours or so. Restarts instantly if you press the concealed reset button above the thermostat.
My boiler engineer says it is either a faulty boiler thermostat, or a faulty temperature cut out sensor, both of which are obsolete parts.
can anyone tell me what parts i need, and where i can source them?
and is this the likely problem?
many thanks
Help please.
many thanks
Not always easy to diagnose across the www but it does seem the original diagnosis could well be right. The problem however is asking about replacement parts because as gas safe registered engineers we cannot really be seen to be encouraging the replacement of parts on a gas appliance for non registered people - it is illegal to work on any gas appliance if you are not competent and are not registered. Far better to get a registered fitter in, even though it is a relatively simple repair to carry out.
Transcoman,
this is an oil fired boiler, so no gas saftey worries.
Of course it is, me stoopid!! I realised that fact an hour or so later when l read it again, too late to change it so thought "What the hell!" 😱 May be worth contacting OFTEC to see if they have any advice.
Reply to the thread, titled "Potterton Perrymatic Jetstreme Mk2" which is posted in UK Plumbers Forums on Plumbers Forums.
