T
twedspeed
Hi My Central Heating boiler is a POTTERTON SUPRIMA 40 and it keeps turning itself off - When it first comes on the radiators heat up and everythings OK for a while, then after about half an hour I feel a little bit chilly and , suprise suprise , the radiators are cooler and I have to go and press and hold the little button on the front panel to get it to work again.
I,m obviously going to have to call someone out to have a look - But just thought I,d try on here first ,
When it first comes on -it makes all the right noises and runs ok and the GREEN indicator light on the panel is lit - But when it turns itself off its a lot quieter and the RED indicator light on the panel is lit.
It comes straight back on when I push and hold the button. but I would like to sit and watch X factor without having to get up and down for a re-set all the time . Any ideas ???
Yeah call a GSR they will sort for you. Not something you'll get advice on here for as could compromise your safety. Good luck.
Reactions: 2 people
Common fault with this boiler ! get ready for a large bill ! dont expect change from £300.00. you will need a gas safe engineer to sort it out.
