Guest viewing limit reached
Potterton Suprima 40L Problems
View the thread, titled "Potterton Suprima 40L Problems" which is posted in UK Plumbers Forums on UK Plumbers Forums.
C
Clarkmeister
I have some recurring but intermittent problems with my system.
Firstly, and most regularly of the problems is my boiler does not stay on and shuts off. I have the controller set by timer and the thermostat but I constantly have to go and click the reset button.
Secondly and most worryingly, every so often I have a loud banging noise from my tank, followed by screeching and usually accompanied with the overflow shooting water out like a hose. It only happens for a few mins and settles down but it is happening a bit more regularly.
I am not looking for advice on how to fix it as I am not qualified, I would like some general ideas of what is going on so I can get someone out to have a look.
All help appreciated.
you need a heating engineer to service/repair your system asap, as there is an overheat issue occuring.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Potterton Suprima 40L Problems" which is posted in UK Plumbers Forums on Plumbers Forums.
Clarkmeister,
Dotty,
