G
glendower
Hi everyone
I have been asked to powerflush a blocked microbore system that has 6mm 8mm and 10mm pipe work. The history behind the blockage is that another plumber drained down the system to fit thermostatic valves to two of the radiators. When he re-filled the system and when he turned it on the boiler cut out after a minute or so. I was told the flow pipe got very hot and the return stayed stone cold. When the boiler had cooled down it was turned on again and the same thing happened. This was done apparently a number of times.
My thoughts are to connect the powerflusher onto the system where the pump is fitted, which is on the return pipe, close off all the radiator valves and turn on the powerflusher with the flow reversed in the hope that this will clear the blockage. Then proceed with normal powerflush.
Sorry for a long first post any advice/tips would be appreciated.
