Power Flush advice needed
View the thread, titled "Power Flush advice needed" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Dear all
I’m a home owner looking for advice.
I recently had a power flush which was unsuccessful at clearing a blocked pipe. I do appreciate these things are not guaranteed.
My question is does time taken reflect on outcome?
The reason I need to understand this is the company employed to undertake the flush declared it having not worked after just 2 hours of flushing (excluding setting up) despite being booked all day. I’m therefore now wondering if they would have cracked on for longer, surely the chances of success would have increased whereas bailing out after just 2 hours seems like I’ve been shortchanged.
Not looking for a witch hunt just trying to understand if time spent flushing is relative to the success in clearing blockages
Thanks in advance.
I've cleared a blockage with air before, it made a hell of a mess when it let go! (Won't be doing it again)
This is my 'cunning plan' for next time!
Once a pipe is really blocked a power flush is probably not going to fix it. If it's a reasonably short and reasonably straight section with easy access to one end it may be possible to 'snake' it. In many cases the blocked section has to be cut out and replaced. If access is really difficult it may be better to bypass the blockage with a new section of pipe in parallel.
Compared with about a day's labour, chemicals, use of the equipment, etc. for a pressure flush, if you know where the block is, it may turn out cheaper to replace the blocked pipe anyway.
Yes agree and in my case it would have been much less labour intensive to have just replaced the pipe, but as my time was free I bought some small gauge wire and rodded the pipes. Took hours and hours but it worked. I then fitted a magnaclean to the flow and this stopped new debris going into the small bore pipe.
Thanks Ric. All ideas are great ideas. Unfortunately the only reason I haven’t just cut my losses and repiped is all pipework is under oak floors that just can’t come up without having to be renewed. So looking for any options that might avoid this. Having said that, it’s a great idea. Thankyou
As my time was free I bought some small gauge wire and rodded the pipes. Took hours and hours (felt like weeks and weeks) but it worked eventually. I then fitted a magnaclean to the flow and this stopped new debris going into the small bore pipe.
What was your eventual solution?
Thanks.
A BSRIA flush should take a number of days if followed correctly to guidance - pre flush - chemical clean/biocide wash - back flush/strainer cleans - dynamic flush - chemical rebalance - chem/bacti sampling etc. They should have been going through the system pipework legs in stages if isolations are present to ascertain where potential issues were to advise if remedials are needed.
If you used a water treatment specialist for the works it's a pretty poor show as they shouldnt have walked away after 2 hours.
Ok thanks Lou. I had an email to check a reply to this thread ! Prompted me to say my central heating pipe work is still working well and the magnacleans are working well. No more blocked microbore pipes !
Reply to the thread, titled "Power Flush advice needed" which is posted in UK Plumbers Forums on Plumbers Forums.
ARLester,
jh2254,
