Guest viewing is limited
Power flushing
View the thread, titled "Power flushing" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Thoggy
Hi all
Got a job to price old glowworm space saver and existing system and I was wondering if putting a tf1 is acceptable for the new combi that I will install, I'm guessing not so how many of you do power flushing and is it something that you need some experience or a case of put machine on and away you go.
i asked because with work like it is I would weigh up buying a second hand machine and doing this myself either that or sub it to someone but the person I know with the machine is likely to try and steal my customer.
also what machines do people recommended on a reasonable price.
many thanks Martyn.
I would do the same as Simon says, put in F3 or X400 a week or so before and then give it a few flushes out with mains when changing the boiler. I would fit a TF1 or Magnaclean as well though!
Cheers guys it's one of those weird cylinders think primatic, it has no header tank its fed from the same piece. So is this a no go for the cleaner product? Also what do you guys do if the boiler is dead on arrival?
you have a few options really, without being able to dose before work on the new boiler is done then i would consider using a power flush machine imo. you could also consider removing the rads and cold flushing outside on a hose and cold flushing the pipework before the new boiler is fitted but this would take longer and you really want to avoid any sludge entering the new boiler by fiulshing before hand.
Drain down at all available points to clean out as much loose muck as poss. You could link out the F+R from cylinder once its removed and try flushing from mains. Then flush with x800 when you've done. Magnaclean should protect the boiler from anything getting inside.
Sent from my iPad using Tapatalk HD
thing is that you need the water to be hot to flush properly or a good flow of water through each rad, so as said before either take rads off or you need a powerflush machine and something to heat the water.
My best advice would be to get someone else to do it unless u have the money to pay for the machine and the heater.
I got a heater built in to my norstrom proflush for when existing boiler is goosed
can you inject cleaner into one rad and let it circulate few days before new boiler install?
as guys said, hire powerflush machine or connect hose and try mains run through, but chemicals probably wont have much of an effect if not heated .
Ah do if I drain a bit off then get a can of the radiator squirt cleaner will this be ok with the primatic cylinder? Cheers for all replies, what's the procedure with flushing do you just put the machine on pipe work and will it be ok flushing with a primatic or easier taking each rad off?
A primatic cylinder hasn't got a coil as such, You cant use chemicals unless you take the cylinder out of the system first.
Boiler is working still just on its way out, don't want to end up with them showering with chemicals but I don't want to fit a nice new boiler on a dirty system.
hire a power flush machine link out the cylinder and flush before you strip out. Charge for the hire of the machine, chemicals and labour ontop of the boiler/system swap. job done. you dont need heat to powerflush but if you have no heat it will take alot longer to flush as heat is an accelerant for the chemical cleaner. Simular to washing up liquid.....ie. works better with hot water.
we pretreat about two weeks before swap double dose x400, and tell the customer they need to run the heating to make it work! powerflush before swap if possible if not on new install. we spend all day flushing, get as clean as possible. we have noticed that on the older systems a year or more later you will still find it is present a bit. now installing magnacleans as well as pf.
I install alot of heat pumps, always fit a Fernox filter, you guys fitting filters on ur heating installs/ services when plumb centre are charging just under £100 + vat?? how is that going down with the customer? p/centre offer me the Magnaclean at £10 less than tf1. or my discount worth **** all?
I explain that it will be better than all the bits going into the boiler and they seem ok with that. Plumb centre is where I go and they are expensive for the majority of things.
When you say link out the cylinder do you mean go day before job and rip out and join up flow and return near where cylinder was?
no, i mean when you do the power flush, you could possible remove the cylinder and attach the power flush pump in its place. or connect the power flush pump at a better point like the pump position or radiator. You will most likely have to charge a days labour as it can take a good day sometimes, if it takes you less then kick on with the new work.
by removing and linking at the cylinder your creating a sealed heating system, which is what you need to powerflush but it cant be left and used in that condition afterwards for obvious reasons.
Reply to the thread, titled "Power flushing" which is posted in UK Plumbers Forums on Plumbers Forums.
Thoggy,
AWheating,
