View the thread, titled "Power shower pump problem" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
T
theoldboy
I had a water pump fitted some time ago to provide a power shower facility. It seemed to work fine for a while but now there's obviously a problem with pressure/air/cavatation. The pump is fitted very close to the outlet to the hot tank, so I can't see how air is getting in. the pump knocks and screams after it has been running for a while.
i've been reading things and I've come across a reference to a flange of some sort. Any words of wisdom anyone can add?
I would go back to the 'plumbers' (not sure plumber is fair, more like fitters) but they went bust and I can't track him down.
It may be the hot water flashing off to steam due to the reduction in pressure caused by the suction of the pump. Try lowering the HW temperature in the cylinder a little to see if that makes any difference.
Also, try to bleed off any air/steam bubbles by moving the temperature control on the shower from hot to cold to hot a couple of times to 'burp' the pipework.
I'll give the first a try - though I'd have thought the higher the tempreture the less draw needed from the hot.
I guess what I'm really after is a fix as opposed to a work round
thanks for the input.
my shower works but I've just had a new pump fitted, when I turn it on it works, however when I turn it off and leave it off it stops working.
Reply to the thread, titled "Power shower pump problem" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
