View the thread, titled "Prehistoric plumbing!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T
traineedrip
Is there any alternative way of capping 3/4" pipe other than comp+3/4 olive?
Anyone know when 28mm copper came out?
I imagine 28mm came out when it changed from imperial to metric, to cap off 3/4 inch I use 3/4x22mm end feed fittings from BES plumbing and then a 22mm end feed cap.
Theres still miles of imperial pipe around.
pulsar do 3/4 sweated caps apparently they still use imperial in Ireland they sent some by mistake recently
Plenty round here in sussex!
Its strange pipe, one end takes a 3/4 olive well but the other ends too loose , must just be bad pipe. No way you could tin the end to build it up in thickness?
I could take it back to the 28mm pipe and work on that... as long as it is 28mm and not 1" copper? 😱
Reply to the thread, titled "Prehistoric plumbing!" which is posted in UK Plumbers Forums on Plumbers Forums.
