A
approach
Hi
I have a Worcester Greenstar 40CDI Conventional boiler. The boiler and CH system is just under 2 years old and never caused an issue but has suddenly become prone to pressure loss .
A recent radiator removal and draining of system was taken 2 weeks ago with no problems up until 2 days ago.
We have checked for leaks on rad valves and visible pipe work. We have lots of oak flooring and tiles down so we have run the downstairs independently, likewise upstairs and had no pressure loss which hopefully indicates we do not have a leak in the pipe system.
There is no water coming from the external pipe from the pressure vessel which suggests that is functioning correctly.
If the Hot Water & heating are run together we get no pressure loss. As soon as we switch to just Hot Water we get a pressure loss of up to 1 bar over an hour. This also happens when we switch the HW off and run the heating independently.
Overnight with no boiler activity we get a total pressure loss.
This maybe not be an issue but the emission/steam coming from the external flue smells of inhibitor? I have not noticed this before.
All rads are bled with no air present.
Hope someone can help.
Thanks :mad2:
Thanks :mad2:
