View the thread, titled "price............just checking" which is posted in UK Plumbers Forums on UK Plumbers Forums.
secret squirrel
Today, I quoted for a basin mixer tap and waste replacement, the waste has a posh push pull thing at the rear of the mixer tap. It is a built in vanity unit and access is not going to be easy. I quoted £80 is this in the right ball park......
My theory is it should only take a couple of hours but I'm learning really fast my couple of hours and reality is longer.........
Your views would be welcome.........
Jpm,
Thanks for the reply, I thought I was about right, sometimes when I give a quote people look at me shocked and I worry that I'm charging too much.
Then I think about the tools we carry and the bits and bobs that you can go just pop to the van for, the annoying drip that just needs a new olive, our knowledge, and I then realise that's what people pay for.
Still doesn't stop me wondering sometimes though.....thanks
Thats about right for two hours without materials, its what I would charge. Maybe not now, but even a year ago, there was plumbers charging more, ecspecially in London.
thats a reasonable price secret as you are building your contacts-once established i would have leaned towards 100.00 plus materials as it could go either way easy 2 hours or crappy 5 but earning 100.00 a day is nice
Is ok but those pop up waste overflows are a pain in the arse sometimes. 90% of the time they are fine though some just leak no matter what you do and it's a bit of a mess around taking it back down two or three times and sealing it again especially if you are tiling a splashback ....so just bear that in mind make sure you seal both under the rim of the top section and again underneath for the overflow section and again on top of the underneath section and make sure it is double tight. Put the rod in first then tighten the top section . Hope this helps. 🙂
Reply to the thread, titled "price............just checking" which is posted in UK Plumbers Forums on Plumbers Forums.
