Just been to a potterton prima F, it starts fine, but after around a minute, the burner starts trying to cut out, the flame is lifting off burner etc before it eventually cuts out! I thought the gas valve was failing and not keeping gas open but its a constant 9 Mbar!
Upon checking the outside terminal to check the fan is staying on I noticed the last 3 inches of flue has rotted through at the bottom! Would this be enough to cause my crazy gas burner flame picture? I have never seen this before on a burner with holes in inner flue!
Is it easy to fit a new inner flue, or is it not worth it on this old thing?
