View the thread, titled "Prima Profile 30e" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Michael2009
I would like to know if there would be any issue on changing the water supply from tank fed to mains supply for the Prima profile 30e boiler. The boiler feeds a hot water storage vessel before distrubution to taps
No problem what so ever,boiler has high limit thermostat fitted,just remove header tank and fit filling loop,pressure release valve,pressure gauge and correct size expansion vessel for system,will not be that big with boiler only 30.000 btu,pressurise system to around 1/2 bar only and away you go 🙂
Reply to the thread, titled "Prima Profile 30e" which is posted in UK Plumbers Forums on Plumbers Forums.
