Hi guys, today my boss has told me to pipe up a boiler with the primary flow having the vent pipe and cold feed going into it.
Is this ok?
The pump is on the flow pumping downwards. He says that if the cold feed goes into the return then the pump will pump the water through the coil and back up into the F& E and then it will all heat up and boil in F&E.
Is this correct or can you have the the vent at the top of primary flow and cold feed into the return?
Thanks for your help
Regards
Lee
Is this ok?
Regards
Lee
