I've came across this problem twice in the past fortnight, the first time was in a household, with a combi boiler. I had the pressure set to 1.5bar, and the Radiator was on the 1st floor and so was the boiler.With the boiler on, the Radiator was hot at the bottom and so was the flow and return, but i had the bleed screw completely removed from the radiator and no air or water was coming out, Strange as it is 1.5bar you'd expect it to be flying out. I just said to the woman that she would need to get the system flushed, as i suspected it to be sludge.
Now I have come across this problem again, this time a Commercial sized heating system(gravity fed). when i filled it up it was fine, I bled the radiator until water was flying out, now that its been running for a few days, i went around to air the radiators again and same problem. The Radiator is on the top floor(building is B,G,1,2) and it is a long radiator think it is 3 joined together, It is hot half way along, and at the other side when i try to bleed it no air or nothing comes out. I've tried shuttin the lockshield to force it out but doesn't happen. is it a build up of sludge ? i am in the process of flushing the system as it is around 30 years old and i have added the sludge remover.
Does anyone know what the problem is ?
