Problem with room stat...
View the thread, titled "Problem with room stat..." which is posted in UK Plumbers Forums on UK Plumbers Forums.
dan_the_plumber
Hello all.
Hopefully someone will be able to help. I'v got a room stat which when you turn the dial up manually it clicks and the boiler fires up as it should.
Then when the room reaches temperature it turns off as it should.
But then as the room cools again the boiler does not fire up again.
I figure I just need to replace the room stat? Or could it be something in the boiler needs changing?
Thanks....Dan
Reply to the thread, titled "Problem with room stat..." which is posted in UK Plumbers Forums on Plumbers Forums.
dan_the_plumber,
