View the thread, titled "Problem with stiff nut ..." which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Johnk78
I have a problem with a nut on the hot side of a deck-mixer under a kitchen sink. Used crowsfoot and basin wrench, even tried bacho spanner, but to no avail. It just wont budge.
Any ideas what else I can do? Apart from cutting the pipe and lifting out the sink!
TIA
TIA
Just a thought. If a union won't budge a blowtorch and a spray of easer often helps. In this location you can't probably use a torch. What about a soldering iron to apply heat ??
Just a thought,
i had a very stiff tap nut once that had been sealed with something that had set hard. i used a combination of a tap wrench, one of those iron ones, and a set of adjustables as extra leverage. the nut eventually came loose after a lot of heaving!
its got boss white or simular on it,
get a deep socket set and 1/2 bar on it, not failed me yet.
I frequently have this problem.
Then I sit back and work out which way to turn the nut ...
That reminds me. I usually find it easier to break a connection if I first try to tighten it. I suppose I get an extremely slight movement onto a clean bit of thread that helps break the seal. Worked for me on a 3/4 inch union yesterday.
Easy T
Thanks all I now own a deep socket set came off first time...well sort of but hay i won today 🙂
Sorry for my ignorance, but any chance you can put a link for the deep socket set and 1/2 bar, as i'm slowly collecting my tool's for when i can get a plumbing job.
Wd40 works well in this situation SOMEtimes, apart from that I go for heat as suggested b4.
Hmm!
Toolstation sell a 1/2" washbasin x 3/4" bath box spanner and you can get a tommy bar from somewhere, about £6 for the box spanner. That is of course if you can't afford the deep socket set.
Reply to the thread, titled "Problem with stiff nut ..." which is posted in UK Plumbers Forums on Plumbers Forums.
